Distribution block mounting location ideas
Cumsterdump
Arizona
looking for recommendations as to where i should wire up a distribution block in my 2001 TJ.
in an effort to maintain OEM quality look i want to add a distribution block somewhere in the jeep that i can use to power winches, light controllers, amps, etc. but im curious where would be best.
i dont mean in the engine bay or in the cab i mean where specifically do yall think is a good place to put this? obviously has to be dry, but what about somewhere with lots of room for getting my hands in there, somewhere discreet, somewhere near the battery.
any ideas?
Lots of folks have used the ABS tray. I mounted a box above the battery using a bracket I fabricated that also holds down my optima battery.
-Mac
The ABS tray is where the sPOD has you mount the distribution/solenoid block. If you don't have ABS, its one of the easiest spots to use.
