I've had the Toyota harness & higher wattage Hella bulbs installed for a few months (headlights are properly aimed, so no one is going blind). Here's the issue:
My Jeep was originally Canadian, thus has DRLs. I recently noticed that at idle, the DRLs go dim and then out altogether. Once I start moving again, they come back to life. Low beams and high beams both work perfectly.
I suspect this has something to do with how the lights are getting power while in DRL mode vs while in low/hi beam mode. When in low or hi beam mode, they are powered through fuses & relays connected directly from the battery. While in DRL mode, I think they're still going through the dimmer switch which was never meant to provide the power these bulbs are asking for.
I've tested the alternator and battery and they're well within spec.
Wondering if anyone has experienced anything similar. Am I going to end up burning out my headlight switch?
