Pinion is deep. Take out 10 thou.
I won't do another 44 without a setup bearing. In the past I used the final outer bearing during setup and have gummed up pinion threads trying to seat the outer bearing to run patterns. Even with a setup nut, I don't trust bearing/race mfg's anymore. I've thrown out many that are out of spec.
Apologies for not posting last night. Son had an issue with his XJ so we diagnosed and fixed that instead of working on my gears.
Current pattern:
Pinion shim: .055
Passenger side shims: .288
Driver side shims: .278
Backlash: .070View attachment 633643View attachment 633644
Feeling like this is close, but again, I have no idea what I'm doing!![]()
Same measurements as last time, but with less gear marking compound.View attachment 633837View attachment 633838
Your profile shows you having rubi 44's front and back. Is this for the front axle or the rear?
The reason I ask, is that the coast side looks maybe 1-2 thou shallow, but the drive side looks pretty good. I would experiment by adding 1-2 thou and see what happens. You are all but there. If this is for the rear axle, it's most likely good.
It's the front. Im happy to mess with the shim stack, but all the shims i have are in 5 thou increments... should I try to find some smaller (thinner) shims?
You don't have any 12 or 3 thou shims in the existing shim stack? Mixing and matching to come to a specific number is the name of the game. They don't make a 1 or 2 thou shim, so to get 11 thou would require a 5 and two 3 thou shims. It's a big puzzle. If 5 is indeed the smallest increment you can make, then I would leave you depth exactly as it is. It's really close, and it's the front. If you want to buy another shim pack that includes thinner shims, then that works too.
Pulled the locker and the pinion today. This was in the oil channel for the pinion.
Locker looks OK, but i have an issue. It looks to me, based off of the "M" stamped in it, that the passenger side bearing cap was installed upside down. Should I change it back to match the stamping, or continue to use it as it was? Im leaning towards moving it back to it's original position. Im wondering if that is part of the reason the ring gear failed.
So I can remember in a week when I start the rebuild:
Pass shims: .083
Drive shims: .235
Pinion shims: .072
Pinion tail shims: .044
That looks to be an old generation 3 piece ARB, not a factory locker. I would put the bearing cap back to the correct orientation, but now you have to deal with the notch that was cut out. I'm not sure where the Yukon airline goes, so take that into consideration.
