Cylinder head sealant
alonso
Malta
So guys, Im rebuilding a 4.0 for my jeep TJ. Im in Europe an to get loctite 592 or permatex 59235 is a pain in the a$$, for the cylinder head bolt. I found Wurth 1C engine sealant instead. Did anyone ever used this product. And if yes, how did it hold up?. It says on the information given that it can handle up to 280C. Thank you in advance guys.
The sealant 592/59235 isn't just high temp, it has to be resistant to coolant. I don't see any mention of that on the Wurth sealant.
I may have kept the tube I bought when I had my cylinder head off to replace a broken piston. I'll have to have a look. If I do have it, I'll see how much it would cost to post to Malta.
I much appreciated, i just maybe found a solution to buy arp 100 9904. Which is also a good sealant for that bolt, as far as I raed. I will reply back to you if I dont get it, hopefully it can be shipped. Thank you again my friend.
