Cutting stock bumper?
The blanket is more than I would have done. :)
Looks good!
Sent from my SM-G950U using Tapatalk
would a hand held cutting wheel do the trick as well as a bench one? (even if i sacrifice a little bit of precision)
You gotta have a strong arm and a tight grip with the cutting disc.
If you are not in good shape physically, do not go this route for the disc will fly away from you.
WARNING: If this happens, you might hurt yourself and maybe cut your front grille with your cutting disc .
I used an angle grinder, cutting the bumper down to about 46" and angling the ends to about 45 degrees. Just about the easiest mod ever.
Finished product.
That turned out great. :thumbsup:
For comparison, here's how mine turned out "without" angling the ends. As mentioned, I wanted to put on the MOPAR end caps. Keeping the stock driving lights was also important to me.
I was thinking a simple bar at a 45* angle, something like @JeepNWilly has maybe
I built my bumper using 1/4" thick rectangular steel tube. I cut it based on the shape I wanted and capped the ends welded and grinded to look smooth. It was very inexpensive as the rectangular tub was sitting as scrap at a local steel supply. I have a band saw so it was easy to cut.
Reactions: KCsTJ
This thread is worthless without pics
hey guys, id love to pick up a stubby bumper (however the bank account is disagreeing with me per usual.) ive seen some rigs with the stock bumpers cut down and im wondering what the best way to do this is, my first guess is a sawzall. thoughts?
I cut mine with a sawzall and it turned out great. Just make sure to have 2 brand new heavy duty metal blades, one for each side.
Sent from my SM-G955U using Tapatalk
JK bumper is a whole different animal than what is on a TJ. Sawzall works for those.
I'm curious. Why can't we use a sawzall on the TJ bumper? I've accurately and cleanly cut through much thicker steel than the TJ stock bumper with a recip. I would argue that it is a safer option than a cut off wheel.
No one said you can't. The JK bumper is covered in plastic, and has thinner metal underneath, so the sawzall works great for that without removing the bumper. Someone else pointed out that the sawzall would most likely move around more. Personally, if I was to cut the bumper, I'd take it off and cut it away from the Jeep where it could be rotated.
Reactions: BoldlyGoing
