First Thanks for this forum! I’ve just joined and see a lot of knowledge here.
I’m a fairly experienced home mechanic with decent tools and a lift. But, I’m more old school, and have never dug into the computer control stuff. Believe it or not, worked at Delphi in late 80s testing their fuel injectors that didn't have the greatest reliability back then.
I‘ve other posts and have downloaded the FSM and done diagnostics..
I have a 2006 TJ , 4.0 6 spd. It mainly gets towed for camping and we barely put 1k miles a year on it, so it sits too much.
so as of today, it’s cranking over, I smell fuel, have tried starting fluid and tested successfully for spark at coil rail. It’s not starting at all.
History of problem.
- Won’t start, battery a bit weak, starter disengaging, during cranking. Charged battery, tried with jump, still no start.
- Changed spark plugs, with Autolite Iridium’s , gapped at .035.
- Had more issues with starter disengaging during start, managed to chip starter gear and flywheel.
-Checked CPS, looked damaged from a possible fragment from gear.
-Had starter rebuilt by a good shop.
-Dropped transmission, put in new flywheel.
- Replaced CPS, but used a Standard Mfg sensor. Didn’t see Mopar recommendation yet.
-Was able to get it started, after many tries, ran for just about a few minutes, but idled very poorly. Died, have not been able to restart since then about 3 days ago.
-Got 3 codes on 3 O2 sensors, Heater Control Circuit Low ( P0037, P0051, P0057) and V0155 Lost Communication with Instrument panel. These codes, nor any others have come back.
- Checked 02 wiring near transmission, looked good. Last year, changed B1S2 and B2S2 sensors with recommended NTKs. Other two were not changed as old ones would not budge. Have had no O2 codes in past year.
-Put in another stronger battery ( not new, but fully charged), cranking much better.
-Learned about the fuel issue with regulator or check valve, I likely have this issue as it always took several tries to start after sitting for longer times ( weeks). So I turned ignition on multiple times as recommended, multiple times. Can hear fuel pump run.
-Cranking better still no start, can smell fuel. Wondering about old fuel.
-Checked ASD relay. ASD relay is getting coil signal for about 2 seconds with ignition on, then shuts off if no engine rotation. So, correct as per manual. Checked out ASD and Fuel pump relay functions with multimeter, all good. Also tried swap with another relay previously.
-Checked for 12v at coil rail, and it stays on through cranking for approx. 15 seconds. I assume this indicates a good CPS and camshaft sensor and signal, ASD relay and PCM control of it all.
-Checked coil rail spark with inline tester. All coils and locations firing during cranking.
-Doublechecked one spark plug gap. .035.
-still no luck, battery still holding above 12v.
-Tried starting fluid at Throttle body. I got absolutely nothing that sounded like it wanted to start after several tries!
-Last I pulled and checked Camshaft sensor / OPD. No obvious issues with camshaft drive gears . This was replaced about 5 years ago ( only about 2k miles ago) with Dorman unit, as I didn’t know better. It has Dorman sensor, but I did save the OE unit somewhere. But doesn’t the firing at coil rail rule out a bad sensor?
Since I got spark at coil rail, I am assuming that ignition / PCM working correctly, but with no difference with starting fluid, I must be missing something. I’ve not checked fuel rail pressure since starting fluid didn’t help and I can smell fuel.
My Next steps
-Get a new battery, as sitting and towing ( with an onboard electric braking system ) are likely not friendly to battery.
-Should I just get a Mopar CPS?
-Should I dig out original camshaft position sensor and put it in?
Seems like just part changing to me, if I m getting spark at coil, but I’m clearly missing something. I’m tempted to change plugs again, but believe the Autolites were recommended for this motor.
One last thing, the starter still seems disengage momentarily during a long crank, but much less often with a better battery. Is this normal, just low voltage or anything related to PCM?
Thanks for any help!
History of problem.
My Next steps
