Coolant Filter Cut Apart
Jezza
DFW Texas
Hey y'all, I installed a coolant filter setup a few months ago on the 2005 LJ. My plan was to run it for a few thousand miles, then cut it open and see what it caught or didn't catch. I ended up putting right at 3000 miles on the setup with the filter installed. Pretty shocking the amount of rust and crud it sucked up.
Interesting theory. I suppose in a perfect world, the coolant would never get dirty - but we don’t live in a perfect world.
I’ll be curious to see how filters 2 and 3 look. I wonder if you’ll get less and less crud as time goes on?
I won't know. I changed out the radiator for a new Mopar and flushed the block.
I'd like to see one from a well maintained system.
I just replaced the radiator, water pump, thermostat and hoses. I pulled the block plug and ran clean water through the block and heater core. The system should be pretty clean now. I will probably cut open another one in 6 months.
Running clean water through is not the same as a good flush that removes all the rust and scale.
A couple of pics of the filter installed. Between the filter and the lines it probably holds an additional quart of coolant. I placed it lower than needed to get the base of it in the slipstream under the inner fender. When my new engine is done, hopefully in a month or so I am going to wrap that downpipe down past the starter. That should help for heat as well.
Reactions: SkylinesSuck
That’s pretty slick, what all did you use for the install? Kit or did you have to piece mail it.
I make the filter bases here. Actually it is the same base that I make for the remote trans, fuel, and coolant filters. The only real difference is the filter stud threads. The rest of the lines and such I just pieced together.
Yuck. I bet I could use one of those, when I flushed my coolant system it just wouldn't stop coming out brown. I ran out of space for dirty water and gave up lmao
No concern about a rock getting thrown at it and punching a small hole in it? Seems vunrable in that spot.
I suppose you could get one up there. I could mount it up higher, or do a skid. Probably not an issue for what I do.
Jezza, interesting project, did you observe any coolant flow reduction, I imagine the restriction of a filter would restrict coolant rate fairly significantly? Did you take any steps to compensate for this restriction?
This is another filter I cut open about a week after installing. This Jeep got 3 flushes with Thermocure before I put the filter on. I was shocked at the amount of junk that came out. The filter was so plugged it began to collapse the pleats. I put a new filter on and will check it again in a week or so.
And/or extra strain on the water pump?
