Cool jobsite finds
Working on some property across the street from a sugar plantation/ferry landing next to a river, that was built by slaves, not sure the age. We were digging to put in a sewer line and dug up a bayonet. I took it to a local museum that dated it as very old and that in that area it was known to be several battles between 1830 and 1840.
Pictures? Who has it now, and did they know country/region of origin?
The guy who owned the land had it coated to preserve it because it started rusting after being uncovered. I know him, next time I see him I'm going to ask if he stills has it, that was 30 years ago. I found this little tidbit where this was found at.>>Over the years, Fort Velasco has taken many shapes and locations. The first Fort Velasco was built during the Mexican Republic (1830 – 1835); the second was modified and maintained during the Texas Revolution and Republic Period (1835–1845); and the third and fourth Forts Velasco were established during the American Civil War Period (1846-1865).
I don't know Texas history well, but I do know that area was very contested during that period, early-mid 1800's. Wasn't the Alamo during that time or in the early 1840's? I don't know the location, but that's a pretty cool piece of history. Somebody probably dropped it while they were quickly "advancing" in a particular direction with no time to turn back. :sneaky:
We have a circa 1900 money pit, I mean house. Well, the tax form says it was built in 1900 but a local historian says they've seen other records indicating it goes back to the 1860s.
When the house was first electrified, it was with knob and tube, and some of it was still in use when we purchased the house in 2010. What I did not know about knob and tube, or at least the way the original installer installed it in our case, was that the neutral return was often daisy chained for all circuits and the hot wire was home to the fuse box for each circuit. When we bought the house, the fuse box had been replaced with a circuit breaker panel and maybe three or four circuits remained on the knob and tube.
Before I got too deep into rewiring, I was just changing some switches and outlets here and there. I would switch off the circuit I was working on but would sometimes still get shocked by the return, because it was carrying return voltage from another circuit. You would think I would have learned my lesson and started switching the main off when I was working on anything. Another time I was slithering on my back under the house (crawlspace) and crossed over a hot exposed wire that was just lying in the sand. That one hurt like a MF, as I was in contact for a couple of seconds with a sweaty back before I could slither off of the wire. I think I was lucky that it was a small gauge wire and there was enough insulation on the wire to limit the surface area.
Now I always turn off the main if I'm near any of that stuff.
We've found old newspapers that were discussing JFK's assassination used as insulation in one of the later additions, and some old large format negatives that somehow ended up under the house. We also had an old dresser in the attic with a stuck drawers that we never really messed with. When we decided to try and open it last year we found about 10 VHS tape cases from 1980s adult films.
Some of the neater things uncovered at the hints you get of the history of what the house may have looked like in the past. We found evidence that two of the rooms had been a carport or porch at some point in their history. We found remnants of an old roof between the drop ceiling of a downstairs room and the room above it. We found evidence of an old stairway that we believe was part of the original house when it was just the center section.
Here is a shot of the house. We think the center section, minus the front porch and the giant columns was the original house. Just a big box with a gable roof. We think the kitchen, which is tucked in behind the little porch you see sticking out on the far left and would have stuck out from the "big box" was part of the original house as well, as there is a fireplace that used to be big enough to cook a cow in that has been bricked-in to insert size. The rest of the right side was added next, followed by the first section on the left (which we think was a carport) then the actual garage further to the left and the second floor above first section on the left (where the JFK papers were found). Somewhere among these additions they added the big columns and made an addition to the back as well. You can the order somewhat by the type of lumber. All the original stuff is rough sawn true dimension or oversized old growth pine that can catch on fire it you try to drill through it too fast. Later is S4S true dimension lumber, and later you start seeing smaller than true dimension lumber.
Very similar to one of my neighbors house where I grew up. Built in 1864 by a lumber and railroad man. It is now listed as a paranormal house.
That, or the majority, was built in 1864? Must have had some serious money. Where is it located?
It was built before that. It had some additions added to it but this was the completed house in 1864 and has retained its footprint to this day.
The owner was a lumber guy and owned a railroad to move his wood to his mills. Back then, if you owned either of these businesses you were rich, but to own both you had stupid money for the day.
Reactions: BlueC
Location? Living in the South, I know many old houses from this area didn't survive the war, or the "reconstruction" time frame, so it's always surprising to me to see one, especially a large one like that, from that time frame.
Years and years ago I used to work for a local county weed and pest as a summer gig. We were spraying in an itty bitty town (with a population less than 25 IIRC). There was a stone pool there. From what I was told by a neighbor in the area, it was initially an old army camp that housed soldiers returning from WWI. Later, it was converted to a POW camp in WWII.
Several years ago I was on a river project in Telluride, CO and we dug up this old hub to a wagon wheel.
Previous job, a client found this old laptop in storage. They were going to have me 'e-waste' it. I was planning to keep it. Then they decided to keep it and put it in a display case in their main office. Oh well.
I was also happy to take a Zip drive (100mb) and a Sony disc man (1st gen portable CD player) from a different person.
Reactions: suicideking
It was a good name! Those were a large part of the late 90's before CD writers became affordable.
Yeah, I bought one to back up our data when I was with Harley's VR 1000 team and had mentioned it to her in passing (she did marketing consulting for a lot of tech companies back then.) She then told me about naming it in a brainstorming session with the client (Iomega). I thought it was cool that I knew the person who came up with that very appropriate name!
