Looking for recommendations on whether to go with adjustable or fixed length control arms.
Background:
Currently in the process of doing a frame swap/restoration and will be cleaning up the axles (Dana 30/35) on the 97 TJ. The jeep used to have a 2" suspension lift but the springs are wore out. Going to switch to the stock height springs since ill be sticking with ~29.5" tires and 15" OEM wheels.
The bushings on the control arms are in need of replacement and I'm going to have to replace the parking brake cables going to each drum with the little mounting brackets being rusted out. The jeep will continue mainly for road use with some light trail usage.
Many of the adjustable versions with the greaseable fittings look much more durable but also way more expensive. Looking to find a balance here. Thank you.
97 TJ Sport, AX-15/NP-231, Dana 30/35
Background:
