Help i did a compression test on my jeep wrangler and all the cyl. had 150 psi except one had 135 psi #3 what would cause that. Its got a pretty bad miss.
You need to do a leak down test. A compression test gives you a general overview of the cylinders condition while the leak down helps you isolate the problem.
