Neither is better and it solely depends on the application. With low power requirements like a radio a fuse is all that is required but on high power applications like fog lights a relay is used otherwise you have to use large capacity wiring and switches to handle the loads.What would be better?
So if you were installing a .2 amp USB charger port you would add a relay ?Both is better.
Total double talk, I'll ask again would you install a .2 amp USB charger with a relay. Not talking about either or, just when to use a relay.I would not install a standalone USB charger. TJs came from the factory with a perfectly fine power supply, and my plug-in adaptor works perfectly.
A relay is not a circuit safety. If you are installing a relay in lieu of a fuse, I would suggest to do some research before working with electrical circuitry. This is not an argument or an insult, it is just a statement and a kind suggestion.
Short answer: NoSo if you were installing a .2 amp USB charger port you would add a relay ?
If I was adding a .2 amp USB charger I would pull power from a non-important key-on fuse behind the glovebox with a fuse tap.Total double talk, I'll ask again would you install a .2 amp USB charger with a relay. Not talking about either or, just when to use a relay.
Exactly.If I was adding a .2 amp USB charger I would pull power from a non-important key-on fuse behind the glovebox with a fuse tap.
A 250 amp breaker for accessories is way excessive, unwarranted, and would protect nothing. If your light bar has LED lights, it barely draws enough amperes to warrant even a small relay. When you don't specifically need a relay for high amp devices, don't install one... they just add another point of failure.Yea I understand how both of these work. I just wanted to hear some opinions. What I am doing in my jeep is sort of both. I bought an additional fuse box and 6 relays for high amp products such as a light bar and so forth. Im going to have a 250 amp breaker from my battery to a fuse box. The relays will deal with the high amp stuff and the relays will be powered through the fuse box (they won’t be connected to the battery directly). Doing this will draw away the high amps from the fuse box and gear them more towards relays. Ask questions if this doesn’t make since.![]()
250A breaker is huge and more than likely way, way oversized - meaning it won't work when needed.Yea I understand how both of these work. I just wanted to hear some opinions. What I am doing in my jeep is sort of both. I bought an additional fuse box and 6 relays for high amp products such as a light bar and so forth. Im going to have a 250 amp breaker from my battery to a fuse box. The relays will deal with the high amp stuff and the relays will be powered through the fuse box (they won’t be connected to the battery directly). Doing this will draw away the high amps from the fuse box and gear them more towards relays. Ask questions if this doesn’t make since.![]()
I don't understand the whole point of this thread? You posted a generic question, with no context. You get understandably obscure and not helpful information in response...Then get triggered because someone was making a point about a USB charger plug? If you know what to do...go do it. why the discussion?My thought process when I bought the relays were for future projects like winch and so forth. I said light bar just as an example. I plan to use fuses for all my leds. The breaker though is a different story I slipped up on tht one. And to the other people discussing the usb. Just tap into 12v socket… idk if you all were talking to me but I’m no idiot lol Ik how low amp stuff works that is why I’m adding a fuse box for my higher amp accessories to run on and to take some of the pressure off my stock one
Never got rude once and I never said anything bout the usb … tht wasn’t directed towards me … so fuck offI don't understand the whole point of this thread? You posted a generic question, with no context. You get understandably obscure and not helpful information in response...Then get triggered because someone was making a point about a USB charger plug? If you know what to do...go do it. why the discussion?
