I tried to start my '05 Rubicon the other day, but when I stepped on the clutch and turned the key nothing happened. Cursing my lazy self for not bypassing the clutch safety switch months ago, I put it into four-low and turned the key. Still nothing. Pushed the transfer case lever back and forth a few more times, and still nothing. Put it back into two-high, stomped on the clutch a few times, and it finally started. After it started I turned it off and put it back into four-low for a try, and it started fine.
The clutch switch problem is understandable, but not starting in four-low has me stumped. What could be the problem with not starting in four-low ,but then starting fine? My dinosaur brain thinks if it was a fuse it would not start at all.
