W Walal123 New Member Original poster Joined Dec 10, 2025 Messages 1 Location Alliance ohio Dec 10, 2025 #1 I have a 2012 jeep wrangler I’m having issues with the clutch. When you press the clutch in and put it in gear the tires move. But as soon as you let the pedal out they stop moving.
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 9,645 Location Fall Creek, OR Dec 10, 2025 #2 So this a Jeep TJ forum...1997 to 2006. I'd check out the JK forum at https://wranglerjkforum.net/ Sounds like you need a clutch. I'd suggest a Luk or a heavy flywheel Centerforce if you're crawling slow. -Mac
hear Can't type Lifetime Supporting Member Joined Oct 18, 2020 Messages 5,539 Location Prosper, TX Dec 10, 2025 #3 Does the tach drop to zero after you let the clutch out? Try giving it more gas before you let the clutch all the way out.
