I have recently purchased a 1999 jeep wrangler. Started out with no issues and I would assume that’s because it had only been driven a few times in about 4 years. Well soon after I started actually driving it i stared hearing a clunking noise when turning left or right in first gear at slow speeds. The noise only happens after driving for about 20 minutes or so. I have replaced all four shocks, passenger side u-joint in the axle, you joint on the driveshaft, rear sway bar links and bushings, and topped off rear differential fluid. I have also been underneath and tighten anything I could find that was loose.
The noise is still there and I’m not sure of the next option. Any help would be greatly appreciated.
