Yes and no , I drove for decades daily going from 5200' - 9052' . It's not like I stopped and re-jetted on my way home from work everyday . The Blazer and K-20 ran just fine.
If you stay at a certain elevation , then it makes sense to re-jet , my ATV and snow blower are re-jetted to 8000'- 10,000' .
Is this like a physical modification or is it just turning a screw / adjusting
Yep, it only made sense of you were staying for a while. I never lived somewhere that had over 3,000' elevation change.
Just for information the worst Carb. EVER for offroad , is a Holley 4 barrel.
Even with an offroad needle and seat they suck!
I can't tell you the number of HOURS I spent trying to get a Holley to work Off-Road... And then only to have it fail again on the next outing.
And not to include the wasted money spent on every bandaid they offered next.
I have no off-road carb experience, but I've been around a Holley on the strip. I'm assuming the off-road guys also used the fancy jet extensions and vent tubes.
Reactions: srimes
Yup , Holley's do one thing well , running wide open for only 1/4 mile at a time. :LOL:
So would the Carter AFB's. I ran them over the Quadrajet but again I think it was due to a stereotype I'd gotten put in my head about them.
The only reason I use a AFB knockoff now , is the cat piss ethanol is absorbed in the nytrofil floats used in a Q-jet , Since the Q-jet was designed to use Gasoline and not Gasohol it can't work as well now. A Q-jet used the newly invented nytrolfil float because it had more bouyency over a brass float. But Gasohol is less dense and the float doesn't float as well. So now a Q-jet runs rich because the float doesn't float as designed. Totally sucks !
Reactions: Wildman
Because AI...:ROFLMAO:
But they did a good job on the Charger....
I honestly can't say why it was I just remember calling them Quadrajunk as a kid... And nobody I knew wanted one.
