Busted radio fuse help
gdel
Connecticut
Hey guys, just bought a 2000. Wondering if anyone had a similar issue or knows how to help. Radio had issues so I decided to do a swap. When I hooked it up to test I realized it wasn’t getting any power. So I looked in the fuse box which is a mess. Previous owner had a bunch of fuse jumpers and wires going everywhere. The radio fuse had a jumper going nowhere so I pulled it out. Fuse is still good and I checked it with another fuse but no luck. When I took out multimeter I found that the radio fuse wasn’t getting 12v. More specifically, the positive part of the radio fuse terminal works when testing to another fuse terminal ground. So I’m guessing the ground part of the radio fuse terminal is messed up. Maybe I busted it when pulling out the jumper. Wipers, lights, and cig lighter work. Anyone have a similar issue? Any help/advice would be appreciated. Thanks!
Figured it out. Don’t know how to delete this thread but it ended up having a ground wire that wasn’t connected right.
