Anyone else changed generic pads recently on your TJ and have one that fits poorly? I first installed Bosch Premium Semi Metallic and now Carquest Premium Semi Metallic; both have the passenger outboard pad kicked out at the top.
The only variables that have changed here are the knuckle (from @mrblaine ) and the pads. I know the knuckle is good; if I put the bare pad in the hangers the arc of the pad fits the arc of the rotor. It is not until the outboard pad is clipped into place on the pins that it is positioned out and I know I did not have this issue with my old pads that were installed (calipers shouldn't be the issue)
I snagged a set of yellowstuff on closeout at Rock Auto for $70; my money right now is that the stamped plates and rivet locations aren't correct on these pads...and all these generic pads probably source the same back plates... thoughts?
