So, a couple months ago I completed a TOTAL brake system replacement...EVERYTHING was replaced. Master cylinder, power booster, proportioning valve, lines both hard and rubber, calipers and wheel cylinders. Now, I attempt to bleed the front calipers after my daughter telling me her Jeep pulls to the left on braking and I get ZERO fluid out of the right caliper. I get fluid with no issues out of the left caliper. I have a union in the line going to the right caliper so I unscrew one side of that connection and still have no fluid there. I unscrew the line from the back of the proportioning valve and I get a little fluid from there.
If the piston inside the proportioning valve has moved to block the front brakes because it sensed a loss in pressure, wouldn't it prevent fluid from coming out of BOTH front calipers?
I have a good strong brake pedal...
Without removing the proportioning valve, I unscrewed the brake light switch from it and it appears to me the piston is not centered and is possibly moved toward the firewall, which would block the front brake fluid supply. I stomped on the brake pedal a few times to attempt to re-center the piston but it did not appear to move. Any suggestions on how to get the piston back centered? I ordered the tool to keep it in the center while bleeding provided I can get it back in the center.
Thanks!
Jeff
Thanks!
Jeff
