Both front brakes dragging
Pcleaners2
Pacifica, CA, United States
Need help
New rotors and pads and brakes still dragging
Can hardly rotate tires by hand
If it helps I do have an 8.8 swap
Had drums before on rear
Rear not the issue though
any ideas
Is there an adjustment somewhere ?? Looked online and didn’t see anything about adjustment of booster
My guess is they're a reman. Did you pull them, collapse the piston and test that they moved without binding? I've installed faulty "new" calipers before. Not likely they're both bad, but it's one more thing to check off the list.
So your saying to push the pistons in and see if they move in. If they don’t move into the caliper then they are binding
They should move in easily, using a brake caliper tool. Then have someone press the pedal lightly, with the caliper off the rotor, and watch that the piston moves out smoothly.
Ok so there is notches fairly deep. Welded them and ground flat
I do notice that both rotors seem a bit thick for the pads or the pads are really thick or the calipers don’t slide back far enough toward the center of the vehicle( in other words centering themselves so the inside pad doesn’t ride the rotor). But the improvement is slight but well see how it is tommorow when I take it out for a longer spin.
This is all ac delco stuff. The rotors and pads and calipers
Not sure how much of a mistake that was but has always stopped good
