Ah okay. Do you think it'd be low enough if you were worried about stalling?With my automatic I've only maybe once wished for a deeper gear. It's amazing how slow it will crawl down or up something.
When I've looked into crawler boxes, they are close enough to the Atlas that I can't imagine why you'd go that route. Atlas is what, 4-5k (the two ratio one) and a crawler box is 2-3? and then you have to deal with a shorter driveshaft, less ratios, etc?This is where it's hard. If you have a crawler case then those times you want taller gears you're limited to 4wd High range. And your only options for multiple gearing is expensive. Be it a Atlas 4 or a Hero box.
Maybe I'm missing something. It has been a while since I've looked.
triple case lol. Bet that wheelbase is nice sometimesMost guys I knew had 5.71 axle gears I think but had the double t-case. I only knew one who had a triple case.
Yeah, maybe I'll have to try it. I think the real question is if I can go low enough to keep the manual - once you get an automatic, a lot of the problems I'm trying to solve via gearing for the manual just no longer applyYes see if Ryan will let you drive his LJ. He has a RubiCralwer so you can really see what low gears are like.
Even if it's only around the parking lot.
