This is the Mitsubishi Dialtone D160, the largest subwoofer ever built, with 60 inches in the 1980s.
Weighing 800kg, it can easily shatter windows and produces small earthquakes that can be felt like ground vibrations within a 2-kilometer range.
At the Koriyama factory, the test was conducted at first in the measuring room, but was stopped because the ceiling lamps fell due to vibration.
The outdoor test appeared to have a negative impact on the neighborhood. At a distance of about 100 m from the speaker, the sound was felt, but at a greater distance, it was transmitted as vibration and noise on the earth instead of an audible sound.
Within a 2-kilometer radius of the factory, damage such as vibrations, small earthquakes, as well as noises from walls and windows occurred
Good thing they don't still build those or someone would have it in a Honda Civic.
Scary, I know what all that stuff is, and have owned or used all of it too. My parents had an electric skillet like the one pictured - it was even the same color, but I think it was a different make. The 5 chalk holder is fairly obscure unless you were in band, which I was. Those old Zenith Space Command remotes were sub-optimal - the TV would go nuts if you jingled coins near it. I actually own a makeup mirror very similar to the one shown, I take it to shows. Viewmaster reels , etc, etc....
  • USA Proud
Reactions: ColoJeep and B252
you must be a zillion years old. I feel like a child again 😊
