Any info or advice on modifying a rear driveshaft double cardan joint for a little more flexibility?
So a 3" 3/16" wall shaft isn't big enough for you?
How about this one?
Ooops. The shaft was so big it didn't all make it into that picture.
(Image courtesy of Punchlikeaflea)
Reactions: jjvw
Honestly, You guys are kinda starting to turn me on a little
My tiny, cut down junk yard xj front shaft just doesn't seem adequate
I just created a quick drawing, explaining something regarding limit straps for a guy so I decided it might be a good idea to use that drawing to add to any other conversations about limit straps. In case someone looking for answers stumbles upon this thread in the future.
Here's the deal with limit straps, they don't need to limit your wheel travel. If you put just a single limit strap over the differential, that will prevent the drive shaft from binding but still allow the axle to see-saw and give you full independent wheel articulation. The attached drawing illustrates this.
