Greetings all - new to the forum. 1999 TJ Sport.... headlights not working. No 12V at the Red/Orange wire at drivers side light, and they feed eachother if I'm not mistaken.
. Suspected the MFS as the dimmer was spotty, so replaced it. No luck. Fuse #1 is good.
My question is about the physical wire routing. Does it stop anywhere between the MFS and the lamp? Because I do not have Red/Orange at the switch (pins 2 and 9 if I recall)... so it's stopping somewhere in the loom on the way to the headlamps. I really would like to avoid cutting up the loom to chase it - I'm about to run new wires and call it a day.
Am I missing something here? From my maint manual and everything I've read online, it's a simple circuit - Battery to fuse #1 - to MFS - to headlamps. The maint manual shows a daytime running lamp module but says Canada-only in one spot, but the schematics don't have a version that doesn't have the daytime running lamp module. This is a USA jeep - sold originally in Florida if I recall the selller correctly some years ago....
TIA
Bob
TIA
Bob
