LONGJP2 TJ Expert Original poster Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,847 Location S. Illinois Sep 7, 2025 #1 Anyone try replacing the pulley bearing on an AC compressor? Mines making noise, gets a little quieter when engaged.
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 9,654 Location Fall Creek, OR Sep 7, 2025 #2 Sometimes you can replace just the clutch. I chased down that rabbit hole for a while... nothing was available for my compressor. -Mac
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 4,140 Location Brookings, Oregon Sep 7, 2025 #3 LONGJP2 said: Anyone try replacing the pulley bearing on an AC compressor? Mines making noise, gets a little quieter when engaged. Click to expand... If your referring to the clutch bearing it's a pretty simple replacement having done it a few times.
LONGJP2 TJ Expert Original poster Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,847 Location S. Illinois Sep 7, 2025 #4 TJ4Jim said: If your referring to the clutch bearing it's a pretty simple replacement having done it a few times. Click to expand... Is that part still available?
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 4,140 Location Brookings, Oregon Sep 7, 2025 #5 LONGJP2 said: Is that part still available? Click to expand... Fortunately it's just a generic sealed roller bearing. Something like this. https://www.napaonline.com/en/p/TEM...ETTAjbH1tSdRRwIOCz2c27U8yEIjiyKdU-iNLwNDRi3mM Reactions: LONGJP2
LONGJP2 TJ Expert Original poster Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,847 Location S. Illinois Sep 7, 2025 #6 Better question. Can I pull the clutch off without removing the compressor? Haven't really looked at it yet.
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 4,140 Location Brookings, Oregon Sep 7, 2025 #7 LONGJP2 said: Better question. Can I pull the clutch off without removing the compressor? Haven't really looked at it yet. Click to expand... Yep
LONGJP2 TJ Expert Original poster Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,847 Location S. Illinois Sep 22, 2025 #8 TJ4Jim said: Fortunately it's just a generic sealed roller bearing. Something like this. https://www.napaonline.com/en/p/TEM...ETTAjbH1tSdRRwIOCz2c27U8yEIjiyKdU-iNLwNDRi3mM Click to expand... Maybe because mine's '06, but that's not the right bearing. That one is 55mm, 35mm, 20mm. Mine is 52, 30, 22.
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 4,140 Location Brookings, Oregon Sep 22, 2025 #9 LONGJP2 said: Maybe because mine's '06, but that's not the right bearing. That one is 55mm, 35mm, 20mm. Mine is 52, 30, 22. Click to expand... Yep, that's why I said like this since they varied over the models.
LONGJP2 TJ Expert Original poster Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,847 Location S. Illinois Sep 27, 2025 #10 Old bearing out, new bering in. Reactions: Spike Strip, macleanflood and TJ4Jim
