6" KC Daylighter A-Pillar Mount Bracket Question
StimpsonJCatt
SE Michigan
For those that have the 6" daylighters mounted to the A-plr, what bracket did you use? I bought the Rough Country version because I liked the corner gusset but the mounting surface for the light isn't long enough and the mounting hardware of the light interferes with the windshield fold hinge and overhangs the front edge of the bracket.
Thanks,
Scott
Thanks,
Scott
I’m using the Quadratec brackets, Slimlites or Daylighters both fit. Looks like the are currently out of stock.
I tried contacting Quadratec today to ask if they could give me a dimension of how long the mounting surface is for the light but they couldn't and mentioned those brackets will not be back in stock till mid June. Good to know they would have fit but I decided to go with the 6" Apollo since the depth is less and they are a bit cheaper. Not a big fan of all plastic but they put out the same wattage and the factory fogs are all plastic.
I have seen those brackets and failed to mention in my original post I was looking for brackets that mount below the windshield hinge. Hoping to still be able to lay the hood against the top of the windshield frame.
Reactions: John Cooper
