Hello,
I recently had a rebuilt transfer case installed in my 1999 Jeep Wrangler (NP231-type I believe). After picking car up from shop, I immediately noticed that the dash 4WD indicator light would not display when engaging 4WD. I assumed it was a faulty switch. No big deal, that was something I could easily replace myself.
I got a new switch (CROWN brand). I disconnected and removed the old switch. Before screwing-in new switch however, I connected it to the electrical connector to test it by manually pushing the steel push ball down with my finger. With the ignition on enough to display all the dash lights, the 4WD indicator light correctly displayed on and off with my manual testing.
I then screwed-in the new switch and attached the electrical connector. When I took a seat in the car, I immediately noticed that the 4WD indicator light was ON... Even though 4WD was not engaged at all. I then raised the transfer case lever into 4H. The light went off! Then pushing the lever all the way back down again, the light came back on.
Has anyone else experienced this issue? Haven't a clue what's going on.
Thanks!
Thanks!
