42RLE slipping on take off in first gear.
2005 TJ Unlimited Rubicon 145k miles.
Derale 20561 Trans cooler along with Two Derale frame rail coolers mount on the grill.
When it is cold there is no slipping but once I drive it, it will slip on taking off.
Trans works fine in the upper gears no slipping.
I was have the torque converter problem not locking up when really hot out 110 plus during the summer.
Caller wrangler fix had a ecu sent to me after talked to Mark.
Installed but it did not solve the problem. I sent it back Thanks Mark great guy.
More studying up on it found the a worn valve body can cause this.
So I got a ATS replacement valve body and installed it.
Then I got the slipping in 1st when taking off.
Replaced the input and output speed sensors.
Have checked the shifter adjustment and it is correct.
Atf4 is just above the full mark when hot.
Any Ideas on why I am getting slipping on take off in first gear
