My 1997 TJ Fuel Pump is not priming and does not get fuel to the fuel rail.
What I have done so far:
- Replaced Fuel Pump
- Checked all Grounds
- Swapped Relay
- Checked Fuses
- Swapped PCM with new Wrangler Fix PCM
- Checked wire harness for any breaks
I have continuity to ground at the Relay. I am not seeing any power at relay C10 slot. My fuel gauge does work.
Not sure what else to check here.
- Swapped Relay
- Checked Fuses
