neither link works, if the trackbar itself moves its a bushing if the bolt moves along with the trackbar the hole is an oval.
None of that movement matters. Get the bolt tight and nothing will move.Also, is this the stock bolt? Or is stock a torx head?
Great, last thing I wanna deal with is PO shenanigansi dont think thats an oem bolt
As it would happen, I do not have a torque wrench. Is torque spec closer to a few grunts with a 1/2" drive rachet or snug with a cheater bar?tighten it back to spec and go about your merry way.
Tighten it till it snaps. Then back it off a little bit.Is torque spec closer to a few grunts with a 1/2" drive rachet or snug with a cheater bar?
That's not what the service manual says. 40 ft lbs for axle side and 60 ft lbs for frame side.Both the axle end and the frame end bolt/nuts need to be torqued to 74 ft/lbs.
