Is it certain year models that are affected or is it a manufacturing time period? Either way, what’s the time period that is prone to cracking?
Thanks @Chris. Looks like my 2000 falls under this. Anything preventative that can be done?
Nothing other than changing the cylinder head unfortunately. Unless your cylinder head already has the TUPY casting on it when you remove the oil cap, then you'll know it was an updated (fixed) cylinder head.
Jeep didn't address this problem until the middle of 2002, so many 2002 models are also affected.It's 0331 casting cylinder heads from 2000-2001 on the 4.0 models.
Sorry to dig up an old thread. Mine is a 2002 and has TUPY casted into it when I look down the engine fill hole, this means I am “ok” and have the updated head that isn’t prone to cracking. correct?
A 2001 4.0L should have the 0331 head that's prone to cracking. The TUPY 0331 head is the improved version. To verify yours, look down the oil fill opening.
What exactly are we looking for under the oil cap? I'm having issues with my 2000 right now. Not sure if it's cracked or head gasket is gone.
