6,400 is higher than I would have guessed. Have you considered this a reason for why your rear end configurations haven’t held up since it sounds like the high weight has been a constant?
Weight surely is a factor, however I'm no longer thinking my issues have been 14b strength related, per se. The 14b should be plenty strong for what I'm throwing at it. Also, I've never actually had a failure with the 14b, just noise and a couple chipped teeth on the pinion. I think my problems all go back to debris causing the chipping of the pinion, and that somehow was related to spinning the original bearing journal. And then my repair of the bearing journal was not sufficient, resulting in the it spinning once again.
At least that's what I'm telling myself so I can sleep at night...
