Never thought about it just being an idiot light. Wow. Always wondered why the dash gauge said 14volts but the battery never read 14.
Or have a vehicle with real gauges like , 02 and older , before our German friends " improved " the TJ .![]()
I believe our '06s have dummy oil/ water/volt gauges.
I wonder how those AGM batteries hold up in a place like Arizona where the heat just destroys batteries. Every lead acid battery I had in Arizona never made it past 2 years.
And, according to AI, whatever that is worth to you, the Marine starting battery is built for harsher conditions, thicker plates, and waves banging.
So it’s “tougher”, but that’s just what the $20 Billion AI Gemini states, not me, so not arguing it ha, for $109 vs $180, I can’t see a reasonable down side.
IMHO the only difference today between a standard starting battery and a marine starting battery are the terminals. Now if you are talking about a true deep cycle marine battery, that is another story.
Not sure why it wouldn’t actually work in my TJ as well next time.
I'm into this one a little over a year now
https://www.oreillyauto.com/detail/...gm/v/a/2324/automotive-suv-2000-jeep-wrangler
It was only $148 to my door, tax included, when I ordered it online. My charging system seems to charge between 13.8 and 14.4 depending on SOC. Like @macleanflood I keep it maintained with a charger. I installed a small NOCO under the hood with the plug poking out near the sway bar and it gets plugged in often. I fully expect to get at least 5 years out of it even with it's one year warranty. It is the exact same battery as their non marine version with the exact same specs and weight but with marine terminals and post terminals both and $100 less plus the additional online discount. They only give it a one year warranty because boat batteries are notorious for neglect. It is made by East Penn but from what I was told, the manufacturer can vary over time and location, but mine is definitely an East Penn.
The specs on this one nearly match that of the Yellow Top Optima.... but it is certainly much cheaper. Need to keep that in mind if the optima craps out in 3 or 4 years. I'll be curious to hear how long the Super Start marine battery lasts for @B1Toad
Not for nothing, but this Marine starting battery from Diehard I posted actually has better specs and is $60 cheaper. I'm interested in seeing if both last a decent amount of time, this one isn't an AGM though.
https://shop.advanceautoparts.com/p/DieHard+MarineBattery:+24M+Group+Size,+1+Year+Warranty,++800+CCA,++1000+CA,++135+Minute+Reserve+CapacityM24-3/16940017-p?utm_source=ET&utm_medium=EMAIL&utm_term=TRNSCT&utm_campaign=20251010_A_TX_ET_ORDCON&utm_content=ITEM
The Gold DieHard that I just replaced was something like 7 years old... I picked it up at Sears before they closed the stores.
Hey Chris - I'm in AZ. I'm running a Premium AGM from O'reilly. It flat lined without any warning after my last drive. There was zero power to it this morning. It's roughly 4 years old.
I was surprised to see that Walmart only sells AGM batteries now.
For those that run AGM batteries, are you also using a battery tender? That's suppose to prolong the life. As I understand it, a vehicle designed for flooded batteries might not always deliver enough voltage to charge an AGM fully. They would benefit from a tender in that circumstance.
