Hey all,
Having an issue with my HVAC that I strongly suspect is the defrost door being stuck by interior debris.
A few years ago my driver door glass shattered and sent glass everywhere including up on the dash area and I specifically remember at least a few prices of glass falling down that I just figured will always be apart of hvac system ha.
I replaced vacuum lines, initially thinking it was a vacuum leak. Interestingly though, I've read that this usually defaults the system to defrost mode for safety reasons. My hvac was stuck on face only, and I could adjust the feet door well enough. I felt vacuum in all areas necessary, albeit weak, so I replaced some of the lines in the engine bay and replaced the section going from the "T" into the glove box.
This did have an improvement (I am pretty sure at least) in the vaccuum I was feeling, but it still wouldn't move that defrost door.
I pulled the actuator off and seems to function fine as far as I can tell.
I reached and really gave it some strength to try and turn this panel door manually with little luck. It moved a little but I heard cracking. I suspected this was the plastic breaking so I did not try to push it anymore.
I was able to free it enough that it will sort of cycle partially, and I can get SOME air to come out the defrost by cycling through the settings on the hvac switch (fairly new switch)
We have an 02 tj at work that I was missing with and those doors seem like they turn much easier in this vehicle.
I dont hear any hissing from any vaccuum lines and I feel vacuum at all hoses. I don't think this is a definitive test, but after feeling how hard it was to manually turn the door, I am fairly sure it is obstructed.
I tried to get in their with about 24" of flexible vacuum hose and it didn't seem to pick anything up.
Has anybody ever disassembled their dash, to cut and access this door area to clear it out? I've heard people use compressed air with some luck, but given that I suspect glass is obstructing, I'm not sure thisnwould be powerful enough to blow this debris out.
If anybody has cut into their hvac or has had a similar experience, it would be great to see some pictures of where you cut into it or what you did to fix it.
Thanks
Thanks
