I watched a feller drop a wheel on dry pavement once......![]()
I may still have pictures, and I wasn't the only witness![]()
I watched a feller try to rip the rear axle out from under his JK on Pritchett once.
I believe after Jeff pulled it back to the AirBnB, I reinstalled that axle and had it ready to do Top of the World the next day![]()
This was your basic, simple, run of the mill JV rear axle shaft failure. It was complicated because of where it broke. The blue line is around the end of the shaft in the tube and we had to pull it out with the winch. The tire on the other side is off because there is problem on that side. We had to get another line on it to stabilize it because when we pulled on the shaft, it tried to pull it over off of the little jacks. They started taking it apart before they got it to a less precarious spot to work on it. This is precisely what happens when you ignore weight and lose focus. View attachment 653068
My intermediate shaft fell off at windrock a few weeks ago, scared the crap outta me.
But I saw this on here a few weeks ago... Little too much gearing and not enough tire...
