1999 Tj Sahara with 2.5L and 5 speed manual
So lately the jeep has been acting as if it has a misfire, but every time I try to run a code and never gives me anything and the check engine light does not stay on. I gave it a tune-up and that seemed to help it but then it started coming back. I started fiddling with wires and I found some on the left side of the engine that were taped together. When I would wiggle these buyers the RPMs would start acting up.
So I followed the set of wires down and they come to a sensor on the top front of the transmission. I was wondering if anyone knew what the sensor was because I might need to do some cutting so I can repair the wires on the permanent side of that sensor clip.
Two of the pictures are of with a sensor meets the transmission, the other picture is the area where it clips into the rest of the harness. As you can see the previous owner taped up the wires and I haven't taken it off yet but I'm assuming it's not looking good under there.
Thanks for the help
Thanks for the help
