HPTuner MPVI2 & VCM Suite Review: 100% Full PCM Access For 2005-2006 Jeep Wrangler TJs
And another little update for the JTEC+ VCM Scanner users. I know alot of us have had issues with the vehicle stumbling with RPM between 2000 and 3000 when scanning. I just applied update 5.2.2 which no longer requires a Beta version to support our TJs and doesn't stumble when scanning!
Is this update a PCM update? Is it available for the 2000 PCM?
When I connect to my 2000 via HP Tuners, I don't see an option to disable the emissions (EVAP). Is there something else I need to do to be able to disable this?
Look in Fuel Sys / Diagnostics ECM45696
It may be what you are looking for.
Reactions: mjonesjr84
Here
No, it's an update to the software on your laptop. I am not aware of a CPS position setting correction that would allow the swap
There are layers of settings around this. First is completing their training to grant access to more advanced emissions and fueling controls.
