Welp, We had a pretty hefty hail storm last night. I did not have anywhere to store my jeep since the garage was full of other cars, so it got to sit out and experience natures danger balls.
Ive got a few new dents in the hood, but everything else is unharmed. Guess its time to do the ole louvers to cover the nasty dents, or look around for a new hood... I don't want the jeep to look like the rocky mountains with its peaks and low spots from the angry ice.
I try to do this, but sometimes the lights around here will be red for too damn long, then a short green and the dude at the front is too busy picking their nose with their phone to realize they need to get moving.
Ive shut my jeep off on occasion due to how shiet the traffic can get around here. :ROFLMAO:
I could never even think about turning the engine off when it's 115+ and full blazing sun. I'd cook before the traffic light turned green.
Welp Got alot of stuff from Amazon,Usp motorsports&rockauto, Got me some ATF for the ole LJ,Mopar RMS,oil pan gasket,trans. Oil pan&lubelocker gasket Autometer guage oh and some new struts for the rear glass 😁
Some Rowe 9008,Works great on the trusty Diesel Gladiator,Shifts were better with this stuff so I'll try it on my Lj🤷‍♂️
Seems to match up decently to the stock cluster 😁,Peep the mini photobomb? Photobomb😆⬇️
Anyways here's some pics of the me getting the bung in 😁 used a Christmas tree bit and reamed the rest of it with my trusty milwaukee die grinder
Some decent fit up 😁
And bam all welded in,got a little offcenter.....
Did a quick leak test with some atf and no leaks after 10 minutes 😁 hopefully I can find someone that can strip and powdercoat this thing before the weekend,my usual guy is backed up so idk😅
Like I said, I’m no expert, but low oil pressure always makes me a little nervous. If it’s around 40 while driving, it’s probably nothing to worry about. I’d just keep an eye on it if it were me.
My friend had a TJ getting some work done at his shop. 290k miles. Dash gauge read around 40-20 psi. He put a real oil pressure gauge on it and it had 5 psi 🤣 It still ran great lol
Rattle can and move on. Powdercoat is overrated
You ain't too wrong on that one.....hell I might bash this pan in someday out In the rocks again, I'd hate to wreck a pan that I spent 80 bucks on for powdercoat......
Plus I can't find no one to do the job so yeah rattle can it is since I can't find no one that can do the job before the weekend which is when I plan on doing my fluid change!
Finished up my adapter plate to make a 03-04 TJ with ax15 swap take an ax15 inner boot. I cut a leather gasket out under the plate so hopefully it keeps the hot air out 🤣
Don't mind the hardware, it's uh, temporary 🤣🤣 hopefully this is a good solution, the only thing I dont like is despite positioning it in the best spot I could find, the rubber boot makes second feel mushy because of the way the boot moves. But I didn't drill any holes in the Jeep so if I don't like it I could try something else.
This last picture is the unobtainable? gasket for an 03-04 jeep. If anybody does know where to buy this, send me a link lol
I got mine through Rock Auto.
Reactions: John Cooper
