I think they’ll function similarly to a trophy truck trailing arm. I believe they run a hard poly bushing on the frame side to prevent the arm from rotating and damaging the shocks that are mounted to it. Then i believe they run a large heim to get the most amount of misalignment on the axle side. It works there but i dont know the specifics such as any downfalls.
Arms don't just flex on one end. In order to get the twist and full flexibility of the narrow joint, the RK joint has to flex just as much. You can test it by rotating your arms to see how they both move together. There's some discussion about front panhard bars where Blaine mentions this.
The specifics of trophy truck trailing arms and bushings on one end I'm not sure, but I do know that if they run a heim on one end and a bushing on the other, both will misalign the same amount to acheive a twist.
Edit: The only thing I could think, is if the axle is twisted and moving the Heim itself and the arm stays "straight." Though I'm not entirely certain to what degree that happens.
Edit 2: Now that I have time to think a little harder, I don't see how it would solely rotate the ball in the heim, considering the pivot point of the axle would not fall on exactly the position of the joint.
