C.J. Roberts
The type of coolant isn't as important as making sure that you're not mixing different types. Mixing orange and green would be bad. If you do a thorough flush, getting ALL the existing coolant out of it, then fill with whatever you get, you should be fine.
Do you know if that coolant you have is premixed with water? If not ONLY mix it with distilled water.
