Have not changed the sign since we moved here in the 70's.
I like the slogan lol
Honestly can’t understand why he would continually be pulled over for that plate. Little dicked cops?
Went for quick drive as it has stopped raining followed by Steak with mushroom sauce at a South African restaurant…
That looks really tasty, though the Zimbabwe flag planted in the beefy goodness confused me a little...I suppose being in the vicinity, the cuisines might be similar?
I did wonder about the flag as well but once I started eating I forgot about it.![]()
Just been working on getting this meth kit installed.
Never mind that ugly hodge-podge of vac line and sensors off the back of the intake manifold![]()
I knew I would run into problems.
PO had put some aftermarket front sway bar end links when they did the 3" lift. Those end links were loose and going bad so I got some Zone Offroad front sway bar end links. I got the old end links off. I was trying to remove the bolt that connects to the axle, and the bolt isn't factory.
It looks like there is a bolt going from the right that then screws into a sleeve on the left. I've never come across something like this before, and I have no idea what this is called.
Any ideas how I can get this off?
I think that's a southwest pattern...
Is this the Southwest flag
Serape
