Anyone installed or used the Undercover Fabrication part # UCF394.
“The Jeep TJ Parking Brake Bracket Kit was designed to mount a Wilwood master cylinder in place of the factory e-brake bracket on the TJ. This is very helpful in performing axle swaps with rear disk brakes. It will plumb in-line with your rear brake hydraulic line and let you use the factory emergency brake handle as a line lock. It was designed for use with "Wilwood 260-6089 .750" Bore Compact Master Cylinder" but it may work with others. The bracket kit will ship welded but bare of any finish. It is attached to the bottom of the tub with factory hardware. You must supply pivot hardware and the hardware to attach the master cylinder.“
I’m interested in it if it works well it might be a great option when I go to the big axles.
