Dana 30 differential fluid change out found small pieces of metal
LarryTJ
SoCal
Changed the fluid on the front differential and found approximately half dozen small pieces of metal attached to the drain plug. Largest piece of metal was 1/16.
Background on this Dana 30: Re-Gear @ 114,000K miles followed by Eaton E-Locker install at 116,000K miles and now at 120K miles. I haven't noticed any unusual noise and the locker operates as designed at this point.
I'm thinking at a minimum remove the cover and inspect ring and spider gear. I know there is a boat load of experience out there and would appreciate thoughts on these small pieces of metal.
Pull the cover & inspect everything then decide how far you need to go.
Also, you don't need limited slip oil with an e-locker
Thanks for pointing that out on the limited slip oil.
