I used a Dakota Digital when I put in my 241OR. The wiring wasn't as elegant as I liked but adjusting the speed is easy as long as you have a passenger to help while you're driving.
They do still have it, I was looking at getting it because I liked the Bluetooth for calibration with my phone, no need to press buttons or turn screws on the device itself.
That's a much nicer solution than my Speedohealer. One of things I can't stand about it is the programming that consists of navigating the menus and value entries using some confusing combination of Morse Code and old video game cheat codes. But that was the Jeep Forum recommendation as the best option way back when.
Agreed! Much nicer setup. And yeah,
Blue Monkey feels like working with an 80's computer every time I find myself dialing it in.
On the plus side though, it's worked flawlessly for 6+ years
Yeah, similar here. I was racing the clock to knock out my SYE and get back on the road to an out of state job.
Kinda half-assed securing the wiring sometime after midnight.
Should have just used gps for speedo and waited until I wasn't under the gun to ensure everything was out of harms way...but hey, it was just replaceable wires. Unbelievable to me is that I haven't had to touch that wiring since then! Maybe I am an amazing auto electrician after all
Since the elegant part seems to be underappreciated, here is what it looks like when done the way we do it. At the firewall, small braided loom is the tap into the PCM harness. The folded back loom is the connector for the old hood light.
Length of loom we run out for adjustment by the passenger while driving.
Fuse tap and a the spot where we tuck the box after we're done. We wrap it in foam sheet so it doesn't rattle.
I am on my second speedo healer. I think the engine bay has too much heat for these devices. Mine was mounted up high on the firewall. Maybe I am the only one that has had this issue, but next time I would pull it inside the cab.
I went with the www.12oclocklabs.com part. They have one all set up for Jeep tj, so simple plug and play then calibrate device. 30 minutes install with calibration. Works great
