Small surface cracks on timing chain cover?
patdugan
Seattle, WA
I'm doing an overhaul of the cooling system (radiator, hoses, thermostat) and while I had some of the components pulled I cleaned off the build-up on the front of the timing chain cover which revealed what look like small surface cracks?
Thoughts on whether or not this is cause for concern or warrants replacement?
Look at your transmission and you will see the same crystallization from the casting process. Those were there from day one. Nothing to fix and nothing to be concerned about.
