Just to clear this up, as Ive read on here alot, cutting your stock ":SHIT" and relocating it is a moron. The factory tin is garbage and should be thrown in the trash once removed.
He seems to be enjoying it in there....Did you capture Rusty Wallace inside your Jeep?
There is a guy in Birmingham with a Gray LJ that has a pair of 44 axles for 2500.00, may be on Craigslist. Thinking they are 4:10 Rubi stuff.I'd probably go with the Currie/Savvy 4" over the MC. If you want to run 37's then you need to plant another money tree but put it somewhere hidden.
Id imagine that Dana 30 is going to struggle, even as a street vehicle. You may want to swap it out to a 44.
Welcome to the forum. Theres a lot here to research in order to run a lift and tires that big.
You can do that in stock applications. A lot of guys leave them off completely. Seems in this situation they are better left in place and tweaked to fit where needed…(edited for accuracy)…17' Big brake kit question on Dana 30. The brake dust shield, trim and use as a shim? Doesnt really fit.
Yes the kit is from him. I cant line it up like its suppose to be. The knuckle is too big for it. And cutting matrial would make it worthless anyway. It would have to be totally reworked if bending it to fit were even an option.
I'd give @mrblaine a call tomorrow or wait for him to chime in but....Yes the kit is from him. I cant line it up like its suppose to be. The knuckle is too big for it. And cutting matrial would make it worthless anyway. It would have to be totally reworked if bending it to fit were even an option.
Thanks, thats all I had to see. But I will call him tomorrow to see if its trimmed to just a shim circle and that "shim" is still bolted on.I'd give @mrblaine a call tomorrow or wait for him to chime in but....
From the photo on his site though it looks like the dust cover was removed.
