Home Garage Vehicle Lift
Kevin E
Lifetime Supporting Member
Wharton, TX
The older I get, the less I want to crawl under my Jeep.
Are there any hydraulic lifts for my garage that you would recommend?
About 12 feet at the low end.
Reactions: rasband
When I turned 50, several years ago, I bought a Bendpak for $1500 from a shop going out of business. Countless hours of use later it was one of the best buys I’ve made. You do need a tall garage for it though or build a tin building for it like I did.
I bought a Chinese 4 post about 6 years ago and it is great, most are made in the same factory in China anyway. If you within a delivery distance of one of the Greg smiths places I would go in and look at them.. 12' is plenty high, my garage is just over 10' high and I could stack 2 mustang convertibles. If you go with a 2 post lift you have to make sure the concrete is a certain PSI to hold it, not so much with a 4 post.
Reactions: SPECWAR and Kevin E
I have a Bendpak Scissors style lift as well. It will hold up to 6,000lbs. Works well and is stable. I like it because it's portable. Here is a picture of my son's Jeep on it:
Here is a review of it: YouTube
I have a MaxJax lift in my garage with a 12' ceiling. https://www.maxjax.com/
I had to change my garage door opener to one that would sit flush against the ceiling, and you get about 54" of clearance under the car at max height. I have an aircraft-repair mobile chair I use so that I can be comfortable while I am working. 120VAC. You can dismount the posts and roll out of the way, if you are so inclined. I keep the one closest to the wall mounted all the time, and mount/dismount the center post as needed. Rated at 6k lbs. Best money I have spent for a tool: nothing else even comes close. Photos below from my frame swap last winter.
When I turned 50, several years ago, I bought a Bendpak for $1500 from a shop going out of business. Countless hours of use later it was one of the best buys I’ve made. You do need a tall garage for it though or build a tin building for it like I did.View attachment 266896
Cool set up, I like to see what other folks can build when there is no consideration for wind loading, ( For me 130mph 3 second gust)
or snow loading, 100 lbs. per square foot. Glad you can get away with far less !
A stool under there is still way better than laying in the ground - that gives me hope for my garage!
Reactions: glowell222
.The older I get, the less I want to crawl under my Jeep.
Me too. Get more exercise or pay a mechanic to do what you obviously don't want to. My 72 year old father (RIP) replaced a 69 GTO JUDGE engine and trans in my brother's driveway by himself. A jack assisted him.
p.s. "No disrespect but" posts always follow with disrespect for some reason. :rolleyes:
Pull the roll bar, fold the windshield and recline the seats!!!
I’d have to, my garage has a beam across the top about 1/3 the way in. I’ll stick to the BFH garage for now and think of my own lift when I buy a second Jeep (probably a XJ that I’ll refurbish for my kids when they can drive).
Reactions: Apparition
