That's ok...we're just a little more originaller than the rest!Huh! I thought I did something original but two folks on this thread did the same thing! Got them from sickspeed.View attachment 59939
Wheredya get the transfer case shift rod?
Shift knob from P.O. Love the way it feels.
The knob I found on Amazon. The straight shifter lever on eBay after I saw it posted here somewhere. Here’s a link to the knob >> https://www.amazon.com/gp/product/B009FRG508/?tag=wranglerorg-20 I did have to tap it out to fit the shifter lever.Where did you find that transfer case shift knob?
I see that it is for a YJ...did you have to drill & tap it, or use an insert with different threads? I don't know how the YJ shift knob attaches...The knob I found on Amazon. The straight shifter lever on eBay after I saw it posted here somewhere. Here’s a link to the knob >> https://www.amazon.com/gp/product/B009FRG508/?tag=wranglerorg-20 I did have to tap it out to fit the shifter lever.
The knob for the transfer case I tapped out, the transmission knob threaded on no problem.I see that it is for a YJ...did you have to drill & tap it, or use an insert with different threads? I don't know how the YJ shift knob attaches...
What stick is that with the bend on the bottom? Or can i just rotate the oem one? I put in a radio on my tj that has a charge station that comes out and folds down. But now my 3rd and 5th gears the now brushes the charge station so i need to gain some roomMore than just a knob.
The stick is a B&M.What stick is that with the bend on the bottom? Or can i just rotate the oem one? I put in a radio on my tj that has a charge station that comes out and folds down. But now my 3rd and 5th gears the now brushes the charge station so i need to gain some room
good god your gear shifter looks like a vibrator
So your saying Silver Bullet????good god your gear shifter looks like a vibrator![]()
We got a lot in common besides derailing threads!!!!!!Twins. Mines gets too hot to handle in the summer.
We got a lot in common besides derailing threads!!!!!!![]()
