Which rebuild kit for upper Currie Trac Bar joint?
DaveF
Bothell, WA
Which rebuild kit do I need for the Currie CE-9120TJJ upper joint? Based on measuring it looks like it might be the 2.5" x 2", but it doesn't look quite like a standard Johnny Joint so I'm not sure if measuring the out side gives me the right information per this graphic? Are the guts the same?
Actual end:
9110rk. I recently put one in after trying to get a seized bolt out of the JJ.
Reactions: DaveF
