What's Your Dream Build
I just want a black, white, green or khaki LJR. With a 2.5" OME lift, 33 inch tires, 1 inch body lift. And if its khaki (my favorite) then a khaki hard top and khaki oem soft top.
GMRS radio. Security glovebox and security something in the back. Maybe drawers. Trail cover. 8k or better winch. Orfab tire carrier and 2 jerry cans. Dirtworx bumpers. And AEV rims.
Now that its written down i gotta get on this!
02 TJ
LS swap, possibly a 5.1 stroker
Either built 4l60e or a 4l80e
Custom atlas or Chevy 241 depending on tranny
14 bolt shaved top and bottom with gun drilled shafts
Dana 44/50/60 hybrid, 99-04 outers, 35 spline gun drilled shafts, Jana 54 kit with load bolt and cover girdle.
Selectable lockers front and rear
Most likely a modified version of the savvy Mid arm, stretched a bit in the back for driveshaft length.
2.0 coilovers with 2.5 bypasses on all four corners, with hydrobumps and a backhalf of some kind
Custom tube fender highlines, boat sides, corner armor and cage.
Probably a custom sway bar setup, maybe some type of quick change gear setup.
Ditch the bench seat and go for a single bucket seat in the middle of the back area.
Custom aluminum center console/sub box with a 10w6 or 10" audiofrog.
Whatever the nicest single DIN HU is at the time, with a kickass audio setup I don't understand quite yet.
Completely sound deadened, MLV/CCF in the doors and all over the tub, quiet as a Cadillac.
PRP seats, 5 point harness with the factory seat belts still useable.
35"x12.5" tires, maybe some 37"s for the snow.
Im probably missing a bunch of stuff, should make a nice DD though lol
I still want that loader backhoe attachment
