Hi Erick & everyone. It took a lil bit of elbow grease to get off the logo being its thin heat set vinyl. If it were a heavy heat transfer you'd just be able to pull it off with the VLR as that's what its really made for. OK, it took me 25-30 minutes with a towel and soft tooth brush. I drug the back end of my new soft top out of the box and laid a towel on the floor just in case of drips. I got the underside of where the logo was completely drenched first with the VLR vinyl solvent and then got all the fabric where the logo was. I let it sit for a minute. Then I took another towel and folded it over and started to rub the logo from the back onto the old towel. Much came off that way but I hear others just did the back then wet the front and started in with a soft brush or took a soft brush to it. Afterwards I just continued to keep it wet and used an old very soft toothbrush to softly work it away and kept keeping it wet on the front and back till it was all removed. Then took another old towel and wiped it down with cold water. I let it dry and you cant tell it was there.
I hoped that helped.
